After windows update yesterday morning i had problems with my plex media server. I had to manually install the windows media foundation package to fix it. I had 2-3 restarts in the process and all the while stablebit was disconnected. I finally had time this evening to open the GUI to see if it would reconnect and it would not. It just sits saying connecting to service until it switches to say there is a problem but continues to try to connect:
Connecting to service (time)
If your are having trouble connecting to the background service try restarting your computer
If your having trouble connecting to a remote computer it may be behind a firewall
When i try to manually start the Cloud Drive service i get the following message:
The Stablebit Cloud Drive Service service on local computer started and then stopped...
in the GUI i was able to see this error once also:
failed to connect to the IPC Port: The system cannot find the file specified.
CloudDrive.Service.exeError0[Main] Unable to start the StableBit CloudDrive service. Error connecting to driver. Make sure that the driver is installed and started. System.ComponentModel.Win32Exception (0x80004005): The system cannot find the file specified
at CoveNative.Helpers.File.OpenExisting(String fileFullName, UInt32 desiredAccess, UInt32 flagsAndAttributes, UInt32 shareMode)
at #ble.#ale.#6ke()
at #ble.#ale.#Nve()
at #ble.#ale.#Lve()2017-01-10 07:35:14Z239218844
Should I be manually reinstalling clouddrive here to try to fix or will that break it further? Looking for next steps to triage. Thanks,
kirkyg
Here is the error reported in the logs:
