jsta Posted December 11, 2016 Share Posted December 11, 2016 I'm not running the disks in a RAID config. They are all standalone disks added to a DrivePool. Scanner says on-disk SMART is not accessible. I would understand if I was running RAID, but I'm not. Ideas? Running 2.5.1.3062. Why is there no Help/About in the interface? Just curious... had to go find the installer to figure out which version I was running. Oh, I do see it displays the version in some of the Settings windows. Quote Link to comment Share on other sites More sharing options...
0 Christopher (Drashna) Posted December 11, 2016 Share Posted December 11, 2016 IIRC, you need to enable the "Unsafe Direct IO" option. You'll also need to have the management software from HighPoint installed, IIRC. Click on the "Settings" button in the toolbar and select "Scanner Settings". Enable the "Show advanced settings and information" option, and hit "OK". You will only need to do this once, from now on, it will always display this option. Click on "Settings", and select the new "Advanced Settings and information" option. Open the Configuration Properties tab. You will find a list of all the settings here, organized into section. Find the "DirectIo" section, and check the "Unsafe" option, and click "OK". Then you will need to restart the service, or restart the computer. To restart the service, run "services.msc" on the system find the "StableBit Scanner Service" and restart it. Or just reboot the system. Once you've done this, it should start grabbing SMART data. Quote Link to comment Share on other sites More sharing options...
0 jsta Posted December 11, 2016 Author Share Posted December 11, 2016 Thanks, I'll give that a shot and report back. Edit: yup, that was it. Thanks! Quote Link to comment Share on other sites More sharing options...
0 Christopher (Drashna) Posted December 11, 2016 Share Posted December 11, 2016 Glad to hear it, and you're very welcome! Quote Link to comment Share on other sites More sharing options...
jsta
Ideas?
Running 2.5.1.3062.
