  • Create Account
10GB connection between two pools - performance tips?
  • Please log in to reply
24 replies to this topic
#21 Umfriend
Umfriend
    Advanced Member
  • Members
  • PipPipPip
  • 373 posts
Posted 12 June 2016 - 08:09 PM
Yes, well, I don't want to replace the cabling, quite a bit of work thaty would be.
Are errors checked/corrected? I mean, if I get to 5GB instread of 10 due to error correction that'd be fine as well.
#22 jmone
jmone
    Advanced Member
  • Members
  • PipPipPip
  • 113 posts
Posted 12 June 2016 - 10:07 PM
Only one way to fine out!
#23 Christopher (Drashna)
  • Administrators
  • 8,208 posts
  • LocationSan Diego, CA, USA
Posted 13 June 2016 - 07:40 PM
I looked at 10GBASE-T  as I too had existing (mix) of Cat5e/6 runs but after reading decided it was just as cheap and more reliable to go fibre.  The spec for 10GBASE-T Lengths is:
- Cat 6a : 100m
- Cat 6 : 55m
- Cat 5e : Not officially supported but some claim you will be fine for small runs but to check the error rates.
This is why I bought a spool of Cat6, the last time I needed cable.  Might as well go for the better stuff... and 55m is more than enough for my house. Especially as the network closet is dead center of the house, basically.
Just need to get 10gig hardware.
Christopher Courtney
aka "Drashna"
This is my server
#24 jmone
jmone
    Advanced Member
  • Members
  • PipPipPip
  • 113 posts
Posted 19 August 2016 - 09:33 AM
Got your 10GBe yet?  All working well for me :)
#25 Christopher (Drashna)
  • Administrators
  • 8,208 posts
Posted 19 August 2016 - 02:40 PM
Nope, it's on the backburner for now.
Tight on funds, and other issues (like getting my server stable...)
aka "Drashna"
This is my server
