  • Create Account
S.M.A.R.T. problem Sharkoon 5-bay RAID Box
  • Please log in to reply
6 replies to this topic
#1 TwoEdge
TwoEdge
    Member
  • Members
  • PipPip
  • 20 posts
Posted 29 October 2015 - 12:14 AM
Hi everyone,
I have a problem reading the smart value of a drive in the Sharkoon 5-bay RAID Box with the Scanner.
This is a known problem with this enclosure but maybe one that could be solved.
With this 5 bay enclosure http://www.sharkoon....1689/11353#descthe smart values of the HDD in the highest slot can't be read.
It doesn't matter if you populate all slots in which case slot number 1 doesn't pass anything or if you just populate the bottom 2 in which case slot number 4 doesn't pass the values.
At least this was the case till today.
I had never tried Hard Disk Sentinel before and so far it is the only tool that got me the values from the top most drive.
Setup:
Scanner v 2.5.2.3103 BETA
HD: SAMSUNG HD204UI
Controller Card: Marvell 92xx SATA 6G Controller (AHCI) [VEN: 1B4B, DEV: 9230] Version: 1.2.0.1027, 6-6-2012
Enclosure Side: JMICRON  RAID #6/1 [14-0]
It is connected via eSata and set to Clear Raid mode, so every drive is directly accessible.
If HD Sentinel can do it, i am sure Scanner will be able, too.
I tried the direct I/O test, was happy to see this
and unhappy to see this
The only specific method that gave me anything was "ScsiMiniportClassDriver" where i got this in the Direct I/O section
The values are messed up but at least it is something.
What are my next steps to figure this out / help to get this working?
Greetings
TwoEdge
#2 Christopher (Drashna)
  • Administrators
  • 8,208 posts
  • LocationSan Diego, CA, USA
Posted 30 October 2015 - 10:22 PM
Did you try the "Unsafe Direct IO" option?
If so, did that work properly?
Christopher Courtney
aka "Drashna"
This is my server
#3 TwoEdge
TwoEdge
    Member
  • Members
  • PipPip
  • 20 posts
Posted 31 October 2015 - 08:47 AM
I tried it and hat the same results as here
#4 Christopher (Drashna)
  • Administrators
  • 8,208 posts
Posted 01 November 2015 - 06:48 PM
Okay, just wanted to make sure.
In that case, could you get the BitFlock ID for the system (either head to bitflock.com or open the SMART details on a disk and select the "Submit to BitFlock" option).
Post the ID here.
Specifically, I think the device ID for the enclosure is not recognized at all, and the default method doesn't work.
aka "Drashna"
This is my server
#5 TwoEdge
TwoEdge
    Member
  • Members
  • PipPip
  • 20 posts
Posted 02 November 2015 - 11:33 PM
The id is "P1PRA7ZE"
#6 Christopher (Drashna)
  • Administrators
  • 8,208 posts
Posted 08 November 2015 - 06:25 PM
Okay, what drive letters are actually in the enclosure here?
And in which order?
https://stablebit.co...eAnalysis/20861
aka "Drashna"
This is my server
#7 TwoEdge
TwoEdge
    Member
  • Members
  • PipPip
  • 20 posts
Posted 08 November 2015 - 11:51 PM
The letters K,L,F and M are in the enclosure.
The top most bay (bay 1) is empty.
Bay 2 to 5 contain K(2), L(3), F(4) and M(5).
It will always be the bay with the lowest number containing a drive that gives trouble with smart values.
If i put another drive in bay 1, drive K in bay 2 WILL show its smart-values.
