  • Create Account
SSD Crucial BX100 250GB : wrong reported SMART temperature
  • Please log in to reply
8 replies to this topic
#1 propergol
propergol
    Advanced Member
  • Members
  • PipPipPip
  • 80 posts
  • LocationFrance
Posted 14 October 2015 - 02:45 PM
I just swapped my system SSD from a Sandisk Extreme II to a Crucial BX100 and I did noticed that temp is read correctly in Scanner's SAMRT detail window (31C) but is wrongly displayed in Scanner's main windows (0C).
BitFlock : RQKIA4F2
#2 Christopher (Drashna)
  • Administrators
  • 8,208 posts
  • LocationSan Diego, CA, USA
Posted 19 October 2015 - 06:45 PM
What version of StableBit Scanner are you using specifically?
Christopher Courtney
aka "Drashna"
This is my server
#3 propergol
propergol
    Advanced Member
  • Members
  • PipPipPip
  • 80 posts
  • LocationFrance
Posted 19 October 2015 - 06:52 PM
The screenshot was made with version v 2.5.2.3103 BETA under Windows Server 2012 R2.
I have just dicided to simplify my setup and give a test to Windows 10 as my server machine rather than running Server R2.
Under Windows 10 with the same Scanner version I face the same issue : 0C reported
#4 Christopher (Drashna)
  • Administrators
  • 8,208 posts
Posted 19 October 2015 - 07:42 PM
.... that's really odd.
Flagged for Alex:
https://stablebit.co...eAnalysis/20829
aka "Drashna"
This is my server
#5 propergol
propergol
    Advanced Member
  • Members
  • PipPipPip
  • 80 posts
  • LocationFrance
Posted 19 October 2015 - 08:29 PM
hmmm... I am thinking  -_- ... I could try to plug the SSD on the M1115 rather than on Intel mobo port.
But since this is my system's SSD I m not sure it would boot.
Will try and report.
#6 propergol
propergol
    Advanced Member
  • Members
  • PipPipPip
  • 80 posts
  • LocationFrance
Posted 20 October 2015 - 03:41 PM
Ok I did test with BX100 on M1115 and it still shows 0C.
#7 Christopher (Drashna)
  • Administrators
  • 8,208 posts
Posted 20 October 2015 - 09:02 PM
I'm not surprised that it didnt' work.
Specifically, the issue here is that there are two ways the drive reports it's temperature. SCT (which is what the problem is) and SMART. SCT is newer and "is supposed to work better" than SMART. But clearly that isn't' the case.  Basically, we need to disregard SCT temp if it's 0C, and use SMART in this case.
Alex is aware of the issue (I talked to him directly about it), and we hope to get to the issue soon.
aka "Drashna"
This is my server
#8 Christopher (Drashna)
  • Administrators
  • 8,208 posts
Posted 12 November 2015 - 06:51 PM
Sorry, this should be fixed in the latest beta builds, IIRC.
aka "Drashna"
This is my server
#9 propergol
propergol
    Advanced Member
  • Members
  • PipPipPip
  • 80 posts
  • LocationFrance
Posted 13 November 2015 - 08:59 PM
Sorry but it isn't  :(
