  • Create Account
SMART values for SSD SanDisk Extreme II and PRO 240 Gb
SanDisk SDSSDXP240Gb SSD SanDisk Extreme II 240 G
  • Please log in to reply
31 replies to this topic
#21 Christopher (Drashna)
  • Administrators
  • 8,208 posts
  • LocationSan Diego, CA, USA
Posted 01 November 2015 - 07:00 PM
Well, glad to hear about the scan errors being fixed!
As for the SMART data, I've recreated the issue, and bumped it up:
https://stablebit.co...eAnalysis/20853
In the meanwhile, could you test a couple of things, just in case:
Click on the Settings button in the toolbar and select Scanner Settings. Enable the Show advanced settings and information option, and hit "OK". You will only need to do this once, from now on, it will always display this option.
Click on Settings, and select the new Advanced Settings and information option. Open the Configuration Properties tab.
Find the "Smart" section and check the "NoWmi" option.
Reboot the machine and see if that helps.
If not, try doing the same with the "Unsafe" option in the "DirectIO" section (and reboot).
If neither help, let me know.
Christopher Courtney
aka "Drashna"
This is my server
#22 propergol
propergol
    Advanced Member
  • Members
  • PipPipPip
  • 80 posts
  • LocationFrance
Posted 02 November 2015 - 05:44 PM
tested : zero change  :mellow:
#23 Christopher (Drashna)
  • Administrators
  • 8,208 posts
Posted 02 November 2015 - 07:14 PM
Okay, thanks for confirming. I've bumped the ticket
aka "Drashna"
This is my server
#24 Christopher (Drashna)
  • Administrators
  • 8,208 posts
Posted 12 November 2015 - 06:53 PM
Well, we got on our hands on a WD drive that was having the scan issues. It looks like it was more than that, and it should hopefully correct some of the SMART issues as well.
If you could download the latest beta build, and see if that helps?
And please do disable the "DoNotCorrectSize" option if you install the previous (3108) build (there is a performance hit to the scan with this setting enabled).
aka "Drashna"
This is my server
#25 propergol
propergol
    Advanced Member
  • Members
  • PipPipPip
  • 80 posts
  • LocationFrance
Posted 13 November 2015 - 09:06 PM
I am sorry to say that it doesnt work, Sandisk SSDs are still showing empty SMART window.
I did even tried "NoWmi" reboot and "Unsafe" reboot : no change  :(
Want me to send you one Sandisk and Crucial SSD?  :lol:
#26 Christopher (Drashna)
  • Administrators
  • 8,208 posts
Posted 14 November 2015 - 08:33 PM
lol, not necessary.  The BitFlock ID should be enough.
Alex has been very busy, which is why we haven't gotten to this yet (Sorry).  However, I will bug Alex about this directly, so we can get it (and related) fixed.
aka "Drashna"
This is my server
#27 gsmer
gsmer
  • Members
  • Pip
  • 3 posts
  • LocationFrance
Posted 02 November 2016 - 10:46 PM
Hi, I've the same SSD, running v2.5.1.3062 on Windows 10, and get the same issue.
I'm updating regarding another issue as you're on it, I'll try to be clear in my explanation :)
Since I installed scanner I've been notified frequently about my ssd overheating. I didn't pay attention because the values were absurd but it became annoying so I've been monitoring with speccy this week as it was mostly happening during gaming session. The value never got over 40 and the max manifactured value is 54 so there's absolutely no reason to alert.
Tuesday checking the forum i discovered I could show the temperature column in scanner (newb there hey !) so I did it and was rather surprised to see that I had the exact same value as in speccy. So it seems scanner can get the real temperature BUT notification sends crap.
Here a copy of one of the mail :
                     StableBit Scanner Heat Warning on "XXXXX". One or more disks are overheating:
  • SanDisk SDSSDXP240G - 132?C (Maximum: 70?C)
    • Model: SanDisk SDSSDXP240G
    • Serial number: 140612401269
Those mails are followed by the end of alert every time like 1 minute later.
Last strange thing, but didn't test it long enough to be statistically significative. It seems that the bug won't happen if scanner is opened in windows (if the gui is open).
Good luck tackling the issue, let me know if you need more details.
Regards,
Gal
#28 Christopher (Drashna)
  • Administrators
  • 8,208 posts
Posted 04 November 2016 - 09:15 PM
gsmer,
There are two (well, three) different places that the temperature can be pulled from. And it sounds like the SSD in question is misreporting one or more of these settings. And likely the SMART value.
Have you tried enabling the "Smart" "NoWmi" option?
http://wiki.covecube...vanced_Settings
That may fix the issue you're seeing.
aka "Drashna"
This is my server
#29 gsmer
gsmer
  • Members
  • Pip
  • 3 posts
  • LocationFrance
Posted 04 November 2016 - 10:29 PM
I've checked the option, i'll let you know in a couple of days if it worked or not.
#30 Christopher (Drashna)
  • Administrators
  • 8,208 posts
Posted 05 November 2016 - 06:41 PM
Well, let me know either way, but hopefully, it does fix the issue.
aka "Drashna"
This is my server
#31 gsmer
gsmer
  • Members
  • Pip
  • 3 posts
  • LocationFrance
Posted 11 November 2016 - 11:21 PM
You were right it does fix the issue, thanks
#32 Christopher (Drashna)
  • Administrators
  • 8,208 posts
Posted 12 November 2016 - 06:14 PM
Fantastic!
I'm glad to hear that.
aka "Drashna"
This is my server
